Anyone know the name of this machine?
5/16/19
Chris Conlon
I have used a machine in the past for rabbets in door frames. I cannot remember what exactly I was using but it worked great.... to describe it; it had a air compression clamp with a friendly handle that was easy to glide back and forth across the cutters... was this a router table or shaper maybe ? I cannot find this online anywhere and I would love to have this setup
5/16/19       #2: Anyone know the name of this machin ...
Dave Sochar Member
A shaper will accomplish this easily. However, there is not a lot of 'back and forth' since it is a linear machine. You only cut in one direction, into the rotation.
If you obtain a shaper, be sure to find out all you can before hooking it up. Talk to older woodworkers and there that may know about it, and be willing to give you a tour and the highlights.
5/16/19       #3: Anyone know the name of this machin ...
Gary R Balcom Member
Chris,
It sounds like you're describing the weaver shaper jigs, run on a shaper.
5/16/19       #4: Anyone know the name of this machin ...
Doesn't sound like a shaper, since you must never go back & forth on one of them.
If it ran a bit sort of like a router it may have been a tenoning attachment. They were sold as part of the multi purpose machines that included a small sliding table saw. I think they were also available as a stand alone. The bit was horizontal, Work was clamped to table that could be moved in all directions with a single handle. They had stops to control depth and end points. The end of the bit had kind of a forked shape. They work well. If you just want to make through grooves a power fed shaper will be much faster but will not make a square ended groove. Be very careful with a shaper. Trying to make stopped grooves is risky. You need to have a stop block set for the start point.
5/16/19       #5: Anyone know the name of this machin ...
How about a matchmaker from woodoworkers supply.
View higher quality, full size image (715 X 523)
5/16/19       #6: Anyone know the name of this machin ...
Stuart Douglas
"Slot Mortiser" ?
5/16/19       #7: Anyone know the name of this machin ...
What kind of cruel game is this? "Tell me what machine I used to use". Kinda like "What's My Line" from when we had black and white TVs with 3 UHF channels!
5/17/19       #8: Anyone know the name of this machin ...
james e mcgrew  Member
I have a Hoffman
View higher quality, full size image (481 X 575)
