Wide Heavy Doors
5/30/19
Ted Ferris Member
Website: https://www.ferrisllc.com/
Hey WoodWeb,
We have a project that calls for 40+ inch wide cabinet doors that are quite heavy (5 lbs/sq ft). Does anyone have experience with projects like this?
What type of hinges did you utilize?
Did you have issues with sagging or warping?
Any information would be very helpful.
5/30/19       #3: Wide Heavy Doors ...
Dave Sochar Member
Assumed to be 'cabinet' doors, not passage doors or similar.
If the above is a correct assumption, then the next assumption is hinge type - cup, or Euro type hinges. If my assumptions are correct so far, then you can go to any of the vendor websites to find out weight and hinge placement as well as count for the hinges.
5/30/19       #4: Wide Heavy Doors ...
MarkB Member
How tall are they?
5/30/19       #5: Wide Heavy Doors ...
Ted Ferris Member
Website: http://ferrisllc.com
They are cabinet doors not passage doors.
We typically use euro hinges and would prefer to in this instance as well if possible
There are only a few doors the one of note is 42" W x 48" H
Thanks for any input
5/30/19       #7: Wide Heavy Doors ...
MarkB Member
I seem to remember a rating on the Salice thick door euro hinges at 20lbs per hinge. That'd put you a bit under with 4 hinges for euro.
5/30/19       #8: Wide Heavy Doors ...
Ted Ferris Member
Mark,
That is a good idea unfortunatley these doors are only 5/8" thick. So the salice thick door hinges will not work in this application.
5/30/19       #9: Wide Heavy Doors ...
How do you plan on keeping them flat? That's a ton of material hanging out there, and made worse with the 5/8" thickness.
5/31/19       #10: Wide Heavy Doors ...
Hello all,
This is a recipe for disaster. Although wider doors can be used with special hinge spacing, 600mm is the widest door specified by all European hinge companies.
I would go back to the designer and come up with another plan. As mentioned above, keeping a door with these dimensions flat will be another issue.
I’m curious. What is the intended use of these cabinets? Kitchen? Closet? Furniture?
Best of luck
Dennis
5/31/19       #11: Wide Heavy Doors ...
By the way, all Salice hinges are rated at 20lbs, not just our thick door hinge.
5/31/19       #12: Wide Heavy Doors ...
Ted Ferris Member
Hey All,
These doors have 5/8" melamine backs that are clad in 16 ga steel. The cabinets will be used for storage of AV equipment adjacent to a fireplace
View higher quality, full size image (1040 X 633)
5/31/19       #13: Wide Heavy Doors ...
MarkB Member
As long as the melamine is not suspect I wouldnt be concerned about warping and even at the weight your talking, with Dennis' response I'd say your fine with the appropriate number of hinges.
Checked back wondering what the door material was to have that weight for such a thin door.
