Twisted barn door
2/27/20
I made a barn door out of pine 2x’s and the horizontal slats were done out of cedar fence pickets. Unfortunately, it was a little bit on the wet side from buying it from Home Depot and ended up twisting the door. I remember doing a job along time ago that had a twisted door, but they install our use some type of turnbuckle he able to rack is the opposite way. Other than using regular turnbuckles, is there a hardware system that will do the same for a door that is 30“ x 82” and that I can use on the backside of the door which won’t end up being seen per se.
2/27/20       #2: Twisted barn door ...
MarkB Member
no, just pull it, have a weiner roast (wait for the finish and stain to burn off before you cook your weiners) and build a new one with quality materials.
2/27/20       #3: Twisted barn door ...
nicko
I built an interior door like that once a long time ago and i pretty much knew it would twist but i took the chance. Guess what? It twisted. So i went and bought the proper kiln dried wood and re built it. There is no good way to pull it straight.
Good luck...........Nicko
2/27/20       #4: Twisted barn door ...
Keith Newton
Hey Mike, I sounds as if you were after some bit of a rustic look by the method you tried. If you are ok with the look, and want to try something, here is what I would try.
While it is still hanging, get down to the bottom, and see how much effort it will take to twist it back to straight. Then go to a steel supply store, and ask to take a feel of how stiff something like 1/4" x 2" or 3" hot rolled wide strap and buy an 8' length.
You should be able to put a bend in the middle or down it's length by putting it in a good vice and pulling hard on the ends. If that isn't enough, put it on some blocks then drive your truck over it.
Once you have some bend in it, screw the ends onto the back of the door with the bend countering the twist. You may need to add some bend, or maybe take some out. Twist and cup are not induced in the direction of the greatest structural properties of wood.
2/27/20       #5: Twisted barn door ...
Quicktrim
You need a stave core and veneers if you want a flat door
2/27/20       #6: Twisted barn door ...
Construction lumber is far from a little wet, it's really wet! Probably going to move every season.
2/29/20       #7: Twisted barn door ...
I will guarantee you will spend more time and get questionable results trying to salvage the door than if you started over with decent materials.
But fence pickets as panel will not cause the door to twist; wet, dry or in between. The twister has to come from one or more stiles and/or rails, or from the joint between the two. Just because the wood is wet/green does not mean it will twist.
I suggest you learn the value of "start flat, stay flat".
    • American Vision Cabinets
    • Salice America Inc.
    • American Fabric Filter Co.
    • INNERGY
