Salice push to open doors and drawers
3/29/20
Robert Guin
This is mainly for Dennis Beam. I build faceframe cabinets with 1/2" overlay doors & drawers. Customer wants no hardware on fronts. Could you give me the part number for a 155 degree hinge that is push to open and also will the push to open drawer guides work on a overlay operation. If so, what is the part # for the 21"guides? I use the rapido hinges on my typical doors. Will I need to also use the push to open magnetic catch on the doors? Thanks for your help.
3/29/20       #2: Salice push to open doors and drawe ...
You too huh?
I need a push to open sink tray flipper door. I can make one with hinges and a Blum tipon plunger, but was wondering if a unit exists that's already made and designed. This is for a full Euro look.
3/30/20       #3: Salice push to open doors and drawe ...
Hello Robert & Leo,
I will answer the hinge question first. For the Push hinge (self opening) you will need both the hinge and a magnetic release device. The magnet does 2 things. First it holds the door in the closed position and second, it acts as a release device to begin the opening movement. The magnetic release device can either be recessed or it can be surface mount.
Here are the catalog pages for the Push hinge and for the release device.
For the tip-down sink front, there isn't anything specifically for this but the 110 degree Push hinge with the recessed magnet is frequently used due to the compact, discrete appearance.
View higher quality, full size image (1019 X 1378)
View higher quality, full size image (1041 X 1375)
View higher quality, full size image (1000 X 1379)
3/30/20       #4: Salice push to open doors and drawe ...
More on the Push hinge release devices.
View higher quality, full size image (1053 X 1377)
View higher quality, full size image (1000 X 1373)
3/30/20       #5: Salice push to open doors and drawe ...
Push to open drawers:
A7557/533CP6 - 21" Push drawer slide
A750.010 - 6 way adjustable front clips (pair)
AGSKXC5 - Metal rear socket (each)
6 pair per box.
Front clips and rear sockets sold separately
View higher quality, full size image (1057 X 1380)
3/31/20       #6: Salice push to open doors and drawe ...
Robert Guin
Thank you Dennis Beam. I can always count on you for help on Salice products.
3/31/20       #7: Salice push to open doors and drawe ...
Hey Robert,
I just noticed you have 1/2” overlay doors. For this you will use a full overlay hinge and a 6mm face frame mounting plate.
Hinge: C2RSA99
Plate: BAU3R69 (New from Salice)
Has this virus slowed you down at all?
Stay Safe
Dennis
4/1/20       #8: Salice push to open doors and drawe ...
Robert Guin
Thanks again Dennis Beam. After turning 62 in August and also having 2 total knee replacement surgery's during 2019, I am kinda in a semi retirement mode. I have been in the cabinet business for 32+ years and am ready to slow down a little. I am still doing as much as I want. The virus has not affected me much in our rural area here in Georgia. The governor just mandated a shelter in place order today that will go into affect on Friday. This may change things.
Stay safe and thanks again on the help with the Salice products.
4/1/20       #9: Salice push to open doors and drawe ...
You’re a young man. I turn 69 in May. I still have my original knees but my wife had one replaced in August 19. So I know what you went through.
4/3/20       #10: Salice push to open doors and drawe ...
Ex-Pat Member
On no Dennis, you are not allowed to be 69. Unless you are planning to work until you are 85. You are way too valuable a resource for this community for us to let you go. A world in which we need to figure things out for ourselves? Madness, sheer madness! Stay safe, and thank you for everything you do for us.
4/3/20       #11: Salice push to open doors and drawe ...
Thanks, Ex-Pat. I have been with an outstanding company for the past 27 years and it has been fun being part of this forum. I don't know about 85 but I plan to keep kicking for a while longer.
Keep safe,
Dennis
4/4/20       #12: Salice push to open doors and drawe ...
Robert Guin
Hey Dennis
Do you happen to know Jeff Davis that was a manager at Meyer Laminates in Evans GA? He brought a Salice rep to my shop many years ago and convinced me to switch from Melpa. Was that you? I have never regretted the change. He is at Rugby in the Atlanta area now.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
