Wall cabinets: single unit or ganged
7/16/20
LRMtwo Member
I'm getting ready to build a set of uppers that will be 6 feet wide and two different heights (two doors at one height, then three at the other), frameless carcasses. What are the pros and cons of making them as a single unit vs two units ganged together? Pro for making one unit is that I will be able to keep a uniform space between each door edge, and not have to worry about the double thickness carcass where the two units are joined. Con for a single unit is weight. I'm using 3/4 inch melamine to match the current cabinets, and the cabinets I'm building will take about two full sheets, so close to 200 pounds if one unit. What else should I be looking at?
Thanks!
7/17/20       #3: Wall cabinets: single unit or gange ...
Tom Gafgen
I work alone and find that assembling one large unit takes a bit longer than assembling a couple smaller ones . Also delivery and installation can be tricky alone .
7/17/20       #4: Wall cabinets: single unit or gange ...
Jim Member
One man shop here also.
Smaller is better.
Door spacing is no different on either one if your set up for frameless cabinetry.
7/17/20       #5: Wall cabinets: single unit or gange ...
Jeff
5 doors = 3 cabinets
7/18/20       #6: Wall cabinets: single unit or gange ...
LRMtwo Member
Thanks for the responses! I'm definitely leaning toward ganging.
7/19/20       #7: Wall cabinets: single unit or gange ...
D Brown
3 cabinets with seams between does not look as clean as no seams and one piece.
True it weighs more but the truth be known it also installs in less time , from a one man shop, I typically get help to deliver or install heavy boxes.Good Luck
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
