extended height adjustment
11/1/20
Bob  Member
Anybody have a way of extending the height adjustment on blum hinge Cam plates.
There always seems to be a cabinet or two that are tweaked then I struggle to get doors lined up.
11/1/20       #2: extended height adjustment ...
Move the plate.
11/2/20       #4: extended height adjustment ...
Tom Gafgen
On frameless cabinets Moving the plate a small amount with system holes can sometimes be difficult so I carry a few face frame adapter plates with my installation tools and swap them for the system plates if I need to move them.The screws are offset quite a bit from the system holes and make remounting the plate in a slightly different location easy .
11/2/20       #5: extended height adjustment ...
jonathan mahnken
The non cam adjust cast metal euro plates have a little more throw in them than the cam adjust if its a small amount needed
