Shaper height setup
6/11/21
I am trying to get a better more accurate, more efficient setup for adjusting the height of cutter heads, I do t have the room to have a bunch of machines and cutters set up for individual tasks.
I was thinking digital would be the way to go, , I have looked at pro scale and wixey, but I am not sure how to mount them on a spindle.
The other option is some pre machines pieces to get it close and then fine tune.
Just wondering what everyone else is doing?
6/11/21       #2: Shaper height setup ...
R Statham Member
I use a machinist height gauge. Once you have the cutter at the correct height. Zero the gauge on shaper table, then measure height of cutter body. You have to write it down for future reference. I am sure there is a way for a DRO to work too, but I use my gauge on multiple machines and works well for me.
6/11/21       #3: Shaper height setup ...
Mark B
Dont waste your time on the Wixey, the resolution is not accurate enough for a shaper. Two options in my opinion are Proscale if you want to do it once and be done with it or a cheaper options is something like an Igaging setup. Either will give you .001 - .0005 resolution. The wixey will not. I cheaped out on the igaging option and it held for a period but eventually gave up the ghost.
There is no way any sort of manual measuring can compete with a DRO and the repeatability is super handy.
Rip the bandaid off and buy the proscale. Mounting the scale is simple even with a little shop fab. You'll be kicking yourself you didnt do it 20 years ago.
6/11/21       #4: Shaper height setup ...
Jr Lee
Spend the extra $$ and buy the proscale. I have tried both Wixey and igage. I have my shaper, table saw and VPS set up with proscale. The only maintenance is new batteries every few months. And the boys at Proscale give excellent support.
Jr
6/11/21       #5: Shaper height setup ...
Adam Spees
I concur with the other guys. There is a reason why Wixey & Igauge are inexpensive. They are cheap. Spend the money on the Proscale and you won't regret it.
6/12/21       #6: Shaper height setup ...
Thanks for the help everyone, I have contacted proscale, they got back to me very quickly with my options.
