Blum Inset hinge with offset
7/9/21
Wayne A Member
Can anyone recommend the Blum hinge for offset. See the attached sketch.
View higher quality, full size image (1388 X 915)
7/9/21       #2: Blum Inset hinge with offset ...
Nathan Wesseling Member
Hi Wayne, You should be able to be able to get this done no problem, use the attached chart and you figure out what hinge plate and tab drilling you need to use.
Chart
7/9/21       #3: Blum Inset hinge with offset ...
Use your normal hinge, 6mm hinge plate and 4mm tab distance should work according to the chart. Hope this helps.
    • Salice America Inc.
    • J&P Machines
    • Original Saw Company
      Industrial Radial Arm Saws
