Concealed hinge - 1-1/4" OL with 1/8" reveal?
9/9/21
MB
Is there such a hinge? And with soft close?
I normally use Blum CLIP top but need the larger overlay, and their Compact hinges require nom. 1/4 reveal. Thanks.
9/9/21       #2: Concealed hinge - 1-1/4" OL wi ...
Blum 155º with a zero plate gets you 1-3/8" overlay.
You need wide door stiles, it gets drilled at something ridiculous like 53mm
A 3mm plate would get you 1-1/4" overlay. Might be better to adjust the boring further to the edge.
9/10/21       #3: Concealed hinge - 1-1/4" OL wi ...
Hey MB,
If you are speaking about a face frame cabinet, the only solution is to scoop-out the frame and recess the mounting plate.
Salice offers a mounting plate perfect for this. With this plate you first bore into the frame 17,5mm ( half a hinge bit diameter). You would use your hinge machine for this operation.
You then put the plate into this half-moon cut-out and attach which ever, full overlay soft close hinge you like. 110 or 155 degree.
C2RKAE9 – 155 degree soft close
C7R6AE9 – 110 degree soft close
Your hinge bore from the edge 0f the door would be 6mm. You can easily maintain your 1/8" gaps.
Of course, this operation is best done prior to assembly of the face frame. I know many shops that use this method for the pie corner cabinet.
Here are some details.
Best of luck,
Dennis
View higher quality, full size image (953 X 516)
View higher quality, full size image (982 X 1358)
9/10/21       #4: Concealed hinge - 1-1/4" OL wi ...
PS. You can do it the hack way too with a router or jig saw but the pocket needs to be made.
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
