Shelf Pullout Hardware
1/6/22
I do not often build cabinets like this, but a good customer has made the request.
As a result, I am looking for full extension shelf hardware, rated at 150 lb, and capable of 40" wide shelves. Low profile, and soft close, too.
Am I dreaming?
1/6/22       #2: Shelf Pullout Hardware ...
Thomas Gardiner
Hettich Actro XL drawer slides have 70-80 kg load capacity. I don't know if they have an anti racking device for wide drawers with this system. I use Hettich slides and think they are great but I haven't used this type
1/7/22       #3: Shelf Pullout Hardware ...
Tom Gafgen
I recently built some drawers 47" wide and 27" deep and used Grass Heavy duty undermount slides . There was absolutely no racking , I was impressed with them .
1/7/22       #4: Shelf Pullout Hardware ...
Hello David,
Salice offers a slide made specifically for this application. Coincidentally, it is called "Shelf". This mounts similar to your typical undermount with the exception that it is not dependent on the cabinet side.
Two slides offer a 75lb load rating while using 4 brings the rating up to 100lbs, dynamic. This would be close to a 150lb static rating. The 40" width would not be an issue. There is no racking.
Shelf is full extension and is available in soft close or "Push" to open. There is also an optional magnetic lock-out kit to prevent the shelf from drifting back into the cabinet while in use.
Shelf is available from Salice distributors nationwide.
Here is a product bulletin for shelf and the link to our web page for this.
Regards,
Dennis Bean
Salice America
View higher quality, full size image (1398 X 1824)
Salice Shelf Drawer Slide
    • Better Vacuum Cups, Inc.
    • Biesse America
    • CP Adhesives
    • Impact Search and Placement
    • Template Services
