MDF Shaker CNC doors warping
1/26/22
Clancy Foor Member
Website: http://www.clancyscabinets.com
Looking for advice.
We CNC 1 pcs HDF Shaker doors that we paint. The doors are warping at different stages in our shop. Sometimes on the CNC. Sometimes in the sanding room. Sometimes in the finish department. Sometimes in assembly.
Sometimes on install.
We keep our raw board flat.
Our suppliers say HDF is better than normal MDF.
We like our 1 piece doors, but something need figured out. Thanks for any advice.
1/26/22       #2: MDF Shaker CNC doors warping ...
Bruce H
We just completed a set with painted applied MDF end panels (painted both sides) The panels changed dimension just sitting in the shop for a couple of weeks (not yet applied) Never had that happen before?...
1/26/22       #3: MDF Shaker CNC doors warping ...
Probably have to do a balanced cut. Some off the back to balance the moisture absorption from the cut areas on the front. The uncut smooth surface absorb considerably less than the cut sections.
1/26/22       #4: MDF Shaker CNC doors warping ...
Chris
We use melamine backed MDF and have had good luck with that. Ranger platinum is the brand.
How deep is your pocketing cut?
1/26/22       #5: MDF Shaker CNC doors warping ...
Adam Spees
As Leo suggested you need to cut some material off of the back. If you look at a traditional 5 piece door the panel is typically back cut.
As to the material, I would assume most materials, regardless of quaility would cup if you cut a huge amount off of one side of the panel.
I suspect the inconsistency of warpage is based how they are stacked between operations. Simply leaving a solid wood raised panel flat on a table will cup it by morning. If we can't assemble doors in a reasonable amount of time, we will stack and clamp the panels down. Otherwise, it can be impossible to get the doors together.
Be very careful with your finishing. You must quickly coat both sides of the doors. They will absorb moisture quickly if only one side is painted.
1/27/22       #6: MDF Shaker CNC doors warping ...
Clancy Foor Member
Wondering if anyone else uses Cabinet Vision to machine Shaker MDF doors?
We are wondering if Cabinet vision has an AZ run for doors?
1/27/22       #7: MDF Shaker CNC doors warping ...
james e mcgrew  Member
HDF (Door Grade) melamine back, is the best for non deflection, moisture and tension movement hands down Mdf is too hit or miss these days
1/27/22       #9: MDF Shaker CNC doors warping ...
Jonathan Mahnken
James do you guys sand and paint the melamine back?
1/31/22       #12: MDF Shaker CNC doors warping ...
If the ''doors' are cupping up at the corners, then they are drying out overnight. Turn them over when you leave today, and they will cup back flat, semi flat, or curl up at the corners as that side dries out.
Use your moisture meter, this is why you have one. Meter some uncut board in its storage place. Note temp and humidity. Then, meter some cut up in the production area, note temp and humidity. Meter at end of day, still flat, then the next morning, when cupped.
I suggest you keep the shop at the same temp, night and day, store your materials in the same place they are to be cut up. Radio Shack used to have a $29.00 temperature and humidity gauge. Amazon will have it today. Storing in cold and moist and then cutting up in dry and warm is not good for the panels.
    • American Vision Cabinets
    • Salice America Inc.
    • American Fabric Filter Co.
    • INNERGY
