Older PolyMac ERGHO 3 bander worth fixing up?
4/20/22
Tipper Member
So I recently acquired an older Biessee PolyMac ERGHO3 bander from a shop that shut down last year. Didn’t pay hardly anything for it so I thought it would be worth a gamble. I just need it to hand shelf and drawer parts with the occasional slab door. Mostly 1 mill banding. Is this old machine worth putting some money into to get going? Would it be good for my purposes?
I think it has pre mill, scraping, buffing ect. Looks like it was a really nice machine back in the day. It was very well maintained and appears to be in ok shape.
I am not familiar with these PolyMac ERGHO 3 banders. What can you guys tell me about them? Any tips or advice?
4/20/22       #2: Older PolyMac ERGHO 3 bander worth ...
Rob Young  Member
I repaired quite a few of those in the early 2000s. One of the big weaknesses was drive mechanism for the glue pot and edge feeder. The universal joints went into a plate with a drive gear and multiple gears for different shafts. The big problem was heat transfer from the glue pot to the drive mechanism and failing bearings. The failing bearings resulted in improper backlash between gears resulting in expensive repairs. I resolved the issue with high temp bearings when I rebuilt them.
If it hasn't been under power for a while you can be certain the operating program is probably gone and you would need to rely on Biesse for that.
With all of that being said, that's a small edgebander, the maintenance technician in me would not rebuild it. The cost to do it would go along way to buying a newer or even new bander.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
