Scalloped cabinet faces??
1/17/23
Jonathan Mahnken
A customer of mine is asking if I can do this style for a double bowl bathroom vanity
View higher quality, full size image (1170 X 2532)
1/17/23       #2: Scalloped cabinet faces?? ...
Jonathan Mahnken
Question is where can I find this material, or file to make it on a cnc router?
1/17/23       #3: Scalloped cabinet faces?? ...
duster
I've done several projects with fluted doors and drawer fronts, as well as some wainscoat panels. I milled the panels on my cnc, using a V Carve Pro fluting toolpath and a 2" diameter ballnose bit.
I used to do these by hand on a large router table I built, but the cnc is much easier and more precise.
I've done some in solid wood, but mostly in mdf. Typically, I would mill a whole sheet, and then cut the pieces to size on a slider.
View higher quality, full size image (800 X 699)
1/17/23       #4: Scalloped cabinet faces?? ...
Can be done in V Carve with a smaller diameter bullnose bit as well using the moulding toolpath. It will have to be set up specifically for your vanity to get the pitch of the scallops correct for the doors. You want to begin and end with full height of the scallop. I'm sure you could use Fusion 360 to do this as well.
1/18/23       #5: Scalloped cabinet faces?? ...
james e mcgrew  Member
I am doing two radius face vanitys the same way next week ! Vcarve / Aspire is excellent for this
1/18/23       #6: Scalloped cabinet faces?? ...
Matt Calnen
I did this one out of solid cherry. Had knifes made and ran the boards through a woodmaster molder. Turned out good and no issues in 10 years. I thought the doors would cup, but they have stayed true enough.
View higher quality, full size image (750 X 680)
1/19/23       #7: Scalloped cabinet faces?? ...
I used a 3/8" bullnose and the profile tool in aspire.
Probably a smarter way to do it. It was a long program to run for these two small fronts out of mdf.
View higher quality, full size image (2992 X 2992)
1/19/23       #9: Scalloped cabinet faces?? ...
It could even be done on a table saw, but lots of scraping and sanding. Those pulls really kill the look and dictate the spacing of the coves to match the center drilling distance.
1/19/23       #10: Scalloped cabinet faces?? ...
Pdub Member
Also just did a set of these on kitchen uppers. Must be a new trend.
We did it from MDF on lift up doors (aventos). Went ahead and embedded some aluminum flat pieces(?) into the back because the MDF wants to cup so bad when you do this.
1/19/23       #11: Scalloped cabinet faces?? ...
Jonathan Mahnken
Thanks guys. So if I do this in vcarve I want to use the fluting toolpath?
1/20/23       #12: Scalloped cabinet faces?? ...
Fluting would work if you have a cutter that fits the full profile of the flute. You'd have to use the molding toolpath like Karl did if not and as he mentioned pretty slow and unless you run a super tight step over (single digits) there will be a fair amount of cleanup.
Depending on the size/profile of the flutes your going for there are several inexpensive options for large diameter cove crown cutters that may allow you to run it in far less passes. Import stuff, but if its a one off Yonico has a lot of very inexpensive options.
When I run these on the CNC I hog out the deepest part of the cove leaving .005-.010" of material in the center where the large cutter is mainly rubbing and it lets you plow along pretty fast with the final pass.
https://www.precisionbits.com/3-radius-horizontal-crown-router-bit-1-2-shank-yonico-16185.html
1/20/23       #13: Scalloped cabinet faces?? ...
One step up the tree.. there may be more options from other suppliers,.. just pulled this off google. Ive used these several times for one off jobs. Carbide is thin, perhaps good for one or two re-grinds if your sharpener goes easy on them but they are pretty much throw aways.
https://www.precisionbits.com/bowl/
1/20/23       #14: Scalloped cabinet faces?? ...
duster
I have several of the Yonico bits Mark B mentioned and they work well for this type of milling. It takes about 10 minutes to mill a full sheet with straight flutes, 12 minutes to do the wave pattern.
View higher quality, full size image (800 X 1067)
1/20/23       #15: Scalloped cabinet faces?? ...
Jonathan Mahnken
Thanks guys
1/20/23       #16: Scalloped cabinet faces?? ...
duster
1/20/23       #17: Scalloped cabinet faces?? ...
Duster,
That horizontal wave wainscotting, last photo in your first response, is pretty smokin. Did you run the wave and then mill a rebate on the panels? I zoomed in and the rail/stile interface looks super clean. Really cool. The transition to vertical at the end of the run is super cool too.
1/21/23       #18: Scalloped cabinet faces?? ...
duster
Mark B - I appreciate your comments regarding the wall panels. It was a fun project that I did for my own house a couple years ago. It took some trial and error to get the look I was going for.
To produce the panels, I milled full sheets of mdf and cut to the sizes needed on my slider. The stile and rails were milled on 2 shapers with a square edge shaker detail, just like a cabinet door. I ran the milled panels through a 3rd shaper to produce the tongue.
Finishing was a bit of a process, with hand sanding, paint, vinyl sealer, 2 different glazes, and lacquer. I showed the finished product to some clients, and actually got some orders for more.
2/8/23       #19: Scalloped cabinet faces?? ...
Kerry Fullington
Modeled in eCabinet Systems Software. (my calculations were a bit off for the width but you get the idea) Would cut it with 1 1/2 round nose bit.
View higher quality, full size image (702 X 740)
2/8/23       #20: Scalloped cabinet faces?? ...
Jonathan Mahnken
Thanks Kerry. Approximately what size are those scallops
2/8/23       #21: Scalloped cabinet faces?? ...
Kerry Fullington
1 1/8" Wide. I set them 1/4" Deep.
2/8/23       #22: Scalloped cabinet faces?? ...
Kerry Fullington
Jonathan,
These came out that size because I wanted to cut them in a single pass. I think you could draw your scallops any width and depth you want and model them using the 1 1/2" tool without too many passes.
2/8/23       #23: Scalloped cabinet faces?? ...
Jonathan Mahnken
1/16/24       #24: Scalloped cabinet faces?? ...
MIke
Would this door stand up built out of recovered cypress woor in an exterior application.
I have a CLient asking for this very thing.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
