Brush sander
12/6/22
Chris
Anyone using a brush sander to help with prepping 1 piece MDF flat panel doors? I’ve been looking at the alpha brush machines as well as Loewer. Any input is appreciated.
12/7/22       #2: Brush sander ...
Robb Parker  Member
Following
1/17/23       #3: Brush sander ...
Adam West  Member
Brush machines can put a polish on the mdf which is actually desirable before priming. The problem is a brush sander follows what is there and not what you want to be there. You need a clean routed area before the piece goes into the brush machine.
Brush machines require a very easy to sand primer to use between coats.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
