4" Bullnose Trim
9/18/23
Gary B
I have an architect asking for 4" Bullnose, so 2" thick, 4" wide trim. Could be paint grade. Any idea where to purchase something like this? I thought about trying to make it, but I can't find a 2" radius shaper cutter. And, for the 10 sticks I need, it wouldn't be worth it. Thanks.
9/18/23       #2: 4" Bullnose Trim ...
MB
Like you said, probably not worth it, but here's an option...
2" radius shaper
9/18/23       #3: 4" Bullnose Trim ...
Leo G
Williams and Hussey molder could do it. Cutters would be about 200-250 for the pair.
9/19/23       #4: 4" Bullnose Trim ...
A cnc can cut this moulding with a 1/2" ballnose bit and a simple toolpath. It takes a long time but yields excellent results. I use V Carve to produce the toolpaths
9/19/23       #5: 4" Bullnose Trim ...
Mark
A 2" radius quarter round or even a bullnose set of knives for a corrugated head would certainly be a viable option IMO
Assuming of course you have the right corrugated head ,3" tall minimum for the bullnose, 2" for the quarter round
9/19/23       #6: 4" Bullnose Trim ...
Mark
A 1" radius quarter round or even a bullnose set of knives for a corrugated head would certainly be a viable option IMO
9/19/23       #7: 4" Bullnose Trim ...
Gary B.
Thanks everyone.
Tom,
This approach sounds pretty good to me. I have CNC's and V Carve. Can you give me an idea of how long this would take for an 8' stick on the CNC? I'll only need about 10 sticks, so this could be viable.
9/20/23       #8: 4" Bullnose Trim ...
It all depends on the step over for the bit. I would choose a fairly coarse step over of about .05" and run the feed at 400 ipm but you know what your machine is capable of. I have run 8' lengths of moulding at about 20 minutes. Smaller moulding but finer steps to minimize sanding. A bullnose is easy to sand so you can run it coarse and clean up once assembled.
