Lock dado captured backs
10/16/23
Gene Davis Member
Please read and comment on this method for the backs of carcases.
As a contractor, with a partner, I built a bunch of kitchens doing the designs, the CAD work in eCabinets to get files to CNC jobbers for the carcase parts, and the onsite builds. I don't do that any more (build), but service contractors by doing the design and eCabs work to resolve jobs down to sourcing: batch files for the CNC, buy lists for the fronts, d'boxes, hardware, and trim.
Twenty years ago I was doing slide-in-from-top backs as 1/4" material in full dados, with pocketscrewed top and bottom nailers of 5/8 PB, the nailers 1/8" inset from the backside carcase edges.
Fifteen jobs ago I changed from something like that to a 4-side captured back, done from 3/4" material same as all other carcase parts, with a lock dado detail all around. eCabs calls a lock dado one that is not continuous, but stops at specified increments for a mechanical fastener, in my case a zipR screw through a CNC'd bored hole.
Whatever the detail, a captured back means you first assemble deck and top (or rear stretcher) to the back, then take the subassembled three-piece array and plug it into the mortises of a side laying on the assembly bench. Then you fit the other side on top, fix with screws, flip the whole thing, and screw the other side tight.
In other words, the backs are part of initial assembly. They don't go on last, like a simple applied-on back, or one that fits into a full perimeter rebate.
For each contractor client doing a job with this detail for the first time, I furnished well-illustrated instructions, and a video showing the method, and there have been no issues. Carcase assembly is fast and easy once you see it and do it.
An image from eCabs of a drawer stack is attached and in it you can see the detail for this 4-sides captured back. Backs are inset 1/8" to allow a tiny bit of scribing and/or wall humps, the same 1/8" I've been doing for many years, 4-side lock dado and before.
Please critique this captured back detail. I might try something new.
View higher quality, full size image (1221 X 883)
10/16/23       #2: Lock dado captured backs ...
The problem with this method is that it requires two sided machining on the top and bottom. Otherwise I like the ensured squareness of the box.
10/16/23       #3: Lock dado captured backs ...
Gene Davis Member
Yes, it requires flips, but the jobber that is doing it, and they've done it for me a number of times, gets flawless results and does not charge more per sheet for the cutting. Go figure.
10/20/23       #4: Lock dado captured backs ...
Gene Davis
Here is the sequence of assembly for a typical base cabinet with this configuration.
View higher quality, full size image (579 X 614)
View higher quality, full size image (654 X 698)
View higher quality, full size image (731 X 697)
10/20/23       #5: Lock dado captured backs ...
Gene Davis
And the final step 4.
View higher quality, full size image (796 X 698)
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
