Computer Aided Design
Subject: Re: Mozaik post processors
8/24/20
Brad
Website: linkedin.com/in/brad-c-b26016180/
I am looking to try Mozaik but I really want a better understanding of how their posts work before I invest anything.
Could someone with experience using and editing Mozaik posts describe the process?
What machine did you write it for? Were there any issues? How long did the process take?
I've set-up, maintained, automated and operated Commercial CNC routers in cabinet shops for twenty plus years and based on the Mozaik website they make it sound like someone like me could use the software to write my own posts. Is that the case?
8/25/20       #2: Mozaik post processors ...
james e mcgrew  Member
Have you contected Moziak, They wrote mine for the CAMaster (.tap) which is easily edited.
Most programs with cam machining find it in their best interest to help or provide a PP otherwise selling software could be difficult
8/25/20       #3: Mozaik post processors ...
Boy am I still asllep !
I see no reason you could not write code with moziak yet I am courious as to why with the softwares capabilities
I use vectric to write special parts and machine it as a separate file
8/25/20       #4: Mozaik post processors ...
SteveL
They already had a post for my machine.
I had a small issue with it at first and they tweeked it for me right away. Mozaik has good support at no extra cost.
8/27/20       #5: Mozaik post processors ...
Peter Matos
As part of the services of using the software they provide you with a post for one machine I believe. When we first started with Mozaik we had some issues getting a working post from them and I believe it was because the machine we have has a bit of an obscure control. Once we explained things to them they were able to get the post written and working in about a week but we waited for several weeks before that happened. If you provide them with a working code from the machine that has all the typical operations in it they can usually get one made reasonably quickly. You can edit the post yourself. I have made several posts for several different machines in other software packages but have not had to do it in Mozaik so not gonna be much help there. I can say that the code it posts while not very elaborate works fine. Have not had any real issues that were found to be code related. The lead ins and lead outs etc are limited. Basically you setup your tool table for what tooling you will be using and assign operation types and parameters for them and the software does the rest. Hope this helps.
Pete
8/27/20       #6: Mozaik post processors ...
They had a post for my Weeke. I paid for an hour to dial things in a bit, maybe a month after we were running with it to work around some of the strangeness in woodwop.
Mozaik is an excellent value for the small shop in my opinion.
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
