Subject: Re: vacuum hose
vacuum hose
12/27/16
DS
Is there an alternate source for vacuum hose that is less money than buying direct from my manufacturer? This is from a Komo VR 510
View higher quality, full size image (747 X 1328)
12/27/16       #2: vacuum hose ...
B.H. Davis Member
Many sources out there. McMaster-Carr is one but there are also some manufacturers that will sell direct. Air Handling Systems is another.
Just do an online search.
12/27/16       #3: vacuum hose ...
Bob Harkleroad
The Blastgate Company
www.blastgateco.com
12/28/16       #4: vacuum hose ...
james e mcgrew Member
Any reason not to use PVC
12/28/16       #5: vacuum hose ...
B.H. Davis Member
Also if you are replacing the hose due only to the kink then just cut and splice it with a PVC or metal coupling.
I do understand that the photo may only be to show the type of hose and you may need it elsewhere as well.
12/28/16       #6: vacuum hose ...
We just buy ours from the manufacturer(Northwood) since they last so long. I think I have gone through 3 sets over 13 years. Each time we order, they are a little different and last longer. I guess they are sourcing better quality hoses as they become available. To the other poster, PVC would not work since that looks to be a moving table machine. The hose has to move with the table and that generates wear over time.
12/29/16       #7: vacuum hose ...
Find a company that supplies hose to vacuum trucks.
12/29/16       #8: vacuum hose ...
cabinetmaker
cut and splice save some cash
1/5/17       #9: vacuum hose ...
Dan
For our Komo we used a hose from Abbott Rubber (abbottrubber.com). The item we needed was (verify the diameter you require) Part # 1220-2500 - Green Black 2-1/2" ID A/W Suction Hose.
Only difference is hose is bright green instead of red. Cost savings even with shipping was substantial. Hose from Abbott has been installed for a few months without any issue. Minimum order was 15' so we did have to cut the hose down to match length we needed.
View larger image
