Subject: Re: Miter saw or portable table saw?
4/27/18
Norm Grimberg  Member
Website: http://mdaltd.ca
Hello everyone, great forums here and your advice has helped a lot in the past!
I am a beginner who has made a few small projects and I'm considering buying either a miter saw or portable table saw: I use our woodshop at work to cut a lot of my wood for my projects and would like to be able to do that at home. Been using the chop saw for cutting 1x2s, 2x4s. I have rarely used the table saw and have resorted to my circular saw and straight edge to cut small boards. Anyway, I do have limited space and thought a portable table saw may be more versital because I can cut flat boards as well as cut 2x4s? Any thoughts are appreciated.
4/30/18       #2: Miter saw or portable table saw? ...
ryan
I would say that table saw if you are willing to take the time to make a good sled for it. Then you can rip and cross cut on the same saw. I do not think this is an idea situation but it will get by until you can buy both. You can make a table saw and sled do what a miter saw will do but not the other way around.
