Aspire Biesse post processor
8/8/15
Jason Scott
I need to find a post processor for aspire to run a Biesse Klever. I think it can be done but it's out of my skill set. If anyone can help I would really appreciate it.
Jason.
8/9/15       #2: Aspire Biesse post processor ...
james mcgrew Member
Have you Contacted Vectric,, There was a problem with the Biesses PP and I am not sure it has been corrected
8/9/15       #3: Aspire Biesse post processor ...
james mcgrew Member
They provide Hundreds of PP included with the software
Here is where these are discussed, (you may have to join the forum
The Klever is listed under current PP available which Version are you using, is it a licensed version ?
8/9/15       #4: Aspire Biesse post processor ...
Jason Scott
Vetrics told me that Biesse doesn't want to help them and won't write a post for them. They have one listed for my machine and it won't work.
At this point I am thinking of using enroute instead.
8/10/15       #5: Aspire Biesse post processor ...
yaakov
if you want ,i can write to you
what format do you use now and its good for you,that can be the base to create pp?
do you have c axiss?
do you have the advance dungle with the bsw?
do you need to export also variable?
do you need to export also tooling table?
8/10/15       #7: Aspire Biesse post processor ...
james mcgrew Member
I had known Biesse had been Difficult for the Machine owners Who wanted to use Aspire,
8/10/15       #8: Aspire Biesse post processor ...
Cesare Magnani
Website: http://www.biesseamerica.com
My name is Cesare Magnani and I am the Brand Sales Manager for the Biesse CNC in North America.
We are totally supportive of all software houses trying to create posts for our machines.
It is obviously in our best interest.
We have been doing it everytime they asked for help.
If we do not know they need help than it is obviously very difficult for us to provide any support.
I am pretty confident there are already Biesse customers using Aspire successfully.
Since nobody from Vectric has contacted us on the topic, and since it appears there are Biesse customers looking for the post, I will make contact with Vectric to understand where they and what is the deal.
You can contact me directly for any question.
Cesare Magnani
Biesse America
cesare.magnani@biesseamerica.com
8/12/15       #9: Aspire Biesse post processor ...
J Wilson  Member
Jason
I sent you a message back over at cnc zone. We have a Biesse Rover G and have been running code from Aspire for 5-6 years now with no problems. I can send you the post I am using that has been tweaked a bit. You would have to REALLY be careful and run some tests, though. Cesare at Biesse is a good man. They (Biesse) have always been able to help me out when needed.
John
View higher quality, full size image (1152 X 864)
View higher quality, full size image (816 X 612)
8/13/15       #10: Aspire Biesse post processor ...
yaakov
as i know Aspire not suport 5 axiss
so pp to biesse very simlple(CID format)
no need iso code
so BSW take care for all security
if you need help call me
8/14/15       #11: Aspire Biesse post processor ...
J Wilson  Member
yaakov
As far as I know, you can not run a program posted by aspire in Biesseworks. The post that I have been using is ISO code run from the older "blue screen" editor. If this has changed, I would love some info :)
John
8/15/15       #12: Aspire Biesse post processor ...
yaakov
wow
its so old pp??
any way if you need or any else
i can create pp direct to bsw(cix format)
