sound enclosure for 10 hp siemens vacuum pump
7/25/19
Rob
Hi guys,
Looking for a company to help us design a noise suppressing box for our 10hp siemens vacuum pump which unfortunately is located within same space as cnc. Have an add-on muffler that does very little. Losing my hearing faster than I would like.
7/26/19       #2: sound enclosure for 10 hp siemens v ...
james e mcgrew  Member
My hearing is Gone, Smart move on your part.
Mine is in a small room behind CMU with plenty of area for heat dissipation, keep heat and ventilation in mind,
have a light or be able to hear slightly when it is on if not controlled by software.
7/26/19       #3: sound enclosure for 10 hp siemens v ...
We keep our 40hp pump in the compressor room. Keeps the noise and heat away from the operator and dust off of the pump. Remote stop and valve operation from near the control.
7/26/19       #4: sound enclosure for 10 hp siemens v ...
Bill Member
Sometimes venting the exhaust outside drops the noise. Not familiar with that pump.
6/2/20       #5: sound enclosure for 10 hp siemens v ...
Melvin Chupp Member
I have a sound proofing cabinet with 2 becker pumps installed. It actually has room for 3. This cabinet was made by Holzher and has two large fans for heat issues. I am not using it currently and would consider selling it and the pumps for the right price. Or just the cabinet.
12/18/25       #6: sound enclosure for 10 hp siemens v ...
SoundBoardW.com Member
Website: https://soundboardw.com/
That sounds incredibly frustrating protecting your hearing should be a priority. While industrial noise suppression needs proper engineering, it’s interesting how awareness of sound carries into digital spaces too. From a soundboard or sound board to sound buttons, soundbutton tools, sound board free options, even meme soundboard trends check out trending sounds and download them at SoundBoardW.com.
4/28/26       #7: sound enclosure for 10 hp siemens v ...
SoundBoardW.net Member
Website: https://soundboardw.net/
Reading this, I can almost hear that brutal vacuum pump drowning everything out - definitely not the kind of “trending sound” I enjoy.
