routing kerfkore
1/12/20
I need to rout some kerfkore perpendicular to the ribs. I'm concerned that the router would knock the ribs loose.
Has anyone done this?
TIA
1/12/20       #2: routing kerfkore ...
duster
I've never tried to route kerfcore, but if I was going to I'd try a down shear bit and climb feed.
1/13/20       #3: routing kerfkore ...
Mike Mandelert
Yes, you will have difficulty. I make my own, but I have a saw on the machine for a thin kerf blade. If you do have a saw, cut the shape first, then make the saw cuts. Been our standard for over 15 years.
1/13/20       #4: routing kerfkore ...
This is a scalloped shape so it has to be routed.
Thanks for the input though
1/13/20       #5: routing kerfkore ...
Jared
I've routed it before, both with straight and downshear bits. It self-destructs like you'd imagine.
1/13/20       #6: routing kerfkore ...
Thanks Jared
1/14/20       #7: routing kerfkore ...
BH Davis  Member
Pat,
One sheet or a large run? If just one sheet perhaps you could rip some filler strips and set them in the slots. Then either kerf down if that can be accomplished without the strips falling out or kerf up with a waste cover sheet (depending on the porosity of the kerf core material).
1/14/20       #8: routing kerfkore ...
Thanks for the idea Bernie
It is just one reception desk.
1/14/20       #9: routing kerfkore ...
cabinetmaker
I Plam the keercore and throw it on the machine Plam side down. We estimate what’s cut where and put strips in with yellow glue overnight Including the access panels for the back area of the reception desk. We use a 3/16 down cut
1/14/20       #10: routing kerfkore ...
BH Davis  Member
Pat,
Another way to do this is to make, say, a curved desk front full height all the way around. Assuming then that you need to cut a pattern into the face of this curved front you can cut that curve on the flat (as you would have done with the Kerfcore) on the CNC into a sheet of 3/8" wacky wood (bending ply).
You can then lay the wacky wood template onto the pre-made Kerfcore front and use it as a routing template for a hand held router with a template guide.
This should give you a clean final cut as the Kerfcore will be locked into position with, I assume, a glued on rear face layer.
An alternative of course is to just cut the pattern into 2 or 3 layers of the bending ply and laminate them together at the final curved shape. Personally I've never been a big fan of Kerfcore and almost always used multiple layers of bending ply.
1/15/20       #11: routing kerfkore ...
I think I'm just going to use mdf as I can use the pony wall as a form and glue 2 3/8" mdf pieces or 1/4" (it's a big radius) with plastic resin glue.
Then make a jig for scalloping the curved piece with a hand router with a guide bushing.
This way I can laminate the edge easily.
Cabinetmaker
Are you saying you glue the filler pieces into to the edge of where you are routing so that they don't interfere with kerkore after the material is cut?
Thanks both of you for good ideas
1/15/20       #12: routing kerfkore ...
jerry Member
We use wiggle board for this kind of stuff
1/16/20       #13: routing kerfkore ...
cabinetmaker
Pat we have run a ton of kerfcore for several projects and have learned just a little extra time in a prep leads to a lot less frustration
Yes estimate the cut area and place filler pieces in the kerf section just enough to let the router cut into solid areas and reduce the blow out. So instead of a just a bunch broken slats after the fact, we have good solid areas that can be painted or laminated
1/17/20       #14: routing kerfkore ...
Thanks Cabinetmaker
What is the advantage of this over forming the on the pony wall? Do you laminate before bending?
