Brema Vektor 15
4/9/21
Brandon Bowling Member
I am pretty new to the coding side of things when it comes to CNC, but I am very mechanically inclined, and have exhausted what I think the mechanical problems could be. So now I am here. The machine is a Biesse Brema 15. I can run 20+ parts without any issue until (on no specific program) the machine will run up to the point it needs to route the long edge, it will engage the proper tool, spin it up, but the part never feeds in for the cut. I get no errors for timing out, it is not showing a pause the program, and the mechanical side of things functions as it should without any issue up to this point. At first I thought maybe the infeed belt was slipping but after watching dozens of parts run, I have ruled that out. Then I turned to the dimensions of the parts in question and compared them to the program, thinking that the feeding of the parts is controlled by the amount of pressure applied to the vertical and horizontal axis, but the parts were well within tolerance. What has really gotten me looking into this is the fact that the machine never errors out, regardless of how long you let it sit in this "faulted" position. At this point I am at a loss, and I cannot get a tech in our facility for another 3-4 weeks. Any help would be greatly appreciated. If you need more info on the machine I can provide that as well, but like I said, I'm not real savvy on the computer side of things.
4/11/21       #2: Brema Vektor 15 ...
Rob Young  Member
Without seeing the schematics it's hard to be specific and not actually seeing the inputs and outputs anything is only a guess. That being said, We sell the Stema line of vertical machining centers and there are board sensing proximity switches at the infeed, in the machine, and the outfeed of the machine to indicate to the PLC if there is already a panel present. I would look at the photo eyes/proximity switches for the panel in machine and exiting the machine to start. If the PLC sees a faulty input for a panel in a location where there isn't actually a panel the machine may be simply pausing till the panel it believes is there has been removed.
4/19/21       #4: Brema Vektor 15 ...
Posting this response as a closer to the issue.
I changed the tool holder for the tool that was giving us the fits without indication or error and the problem has seemingly stopped. I still have a few questions to be answered by the manufacture, but as of today we have ran successfully, and pause/wait free for 3 days. I am still baffled the machine is not set up to time out when this happens, but hopefully the Brema tech can give me some more insight on this when he comes in.
Thank you for the info on the sensors. I will keep that in mind for future occurrences.
    • Limtech Industries, Inc.
