Need CNC suggestions
3/19/22
Tipper Member
So we are looking at buying a smaller CNC to make 1 piece and 2 piece cabinet doors out of MDF. We are primarily a door shop and don’t not want or have the space for a 5x10 machine. I completely understand the sentiment about buying more than you currently need and using the CNC for so many other purposes and future potential business opportunities but we are dead set against that right now. Space is limited and we are behind the 8 ball on offering 1 piece or 2 piece shaker doors,
We have been using the Woodhaven kit for making 1 piece raised panel doors and we are happy with it. But we need the capability to make 1 or 2 piece shaker doors with the 22.5 degree bevel around the inside panel.
With that being said, are there any small 4x4 machines that you guys can suggest? I am not looking to debate on getting a larger machine. We just cant do that right now. Any advice or recommendations would be great
3/19/22       #2: Need CNC suggestions ...
My circumstances are different from yours etc. etc. etc. Just sharing experience.
From our experience the limiting factor in 1 piece MDF shaker doors is sanding the center panel.
In order to keep that to as much of a minimum as possible you need a heavy sturdy machine, solid PCD tooling, preferably one piece - no collets, and lots and lots of vacuum.
I don't think you'll find a heavy enough 4X4 machine and the tooling and vacuum needed to do this well are expensive. White backed MDF can compensate for less vacuum but is more expensive.
Software isn't cheap either.
I have 3 heavy iron 5X10 machines, A Biesse Arrow, A Komo and an ANDI, lots of vacuum, AlphaCAM with the door option, and I don't see that it pays.
3/20/22       #3: Need CNC suggestions ...
BH Davis  Member
You don't need a heavy iron machine. Talk to the PC controlled medium weight machine manufacturers. Many of them either already make or will custom make a 4x4 system for you. Among others I'd talk to CNT Motion, Multicam, Axyz, Techo-isel and CamMaster.
Vacuum hold down is of course a major issue. This can be accomplished with either a high HP regenerative blower system or a much lighter duty, lower cost, shop vac motor system. The shop vac motor systems work so well that there are now companies making them in plug and ply versions. Blackbox is one such company.
Software is the other key component. Since you are primarily going to be making 1-piece cabinet doors look for a package that allows you to purchase the software components you need. Enroute comes to mind for this.
3/20/22       #4: Need CNC suggestions ...
jerry Member
A pod and rail may be a better fit for this as you can do edge profiling along with the center machining
3/20/22       #5: Need CNC suggestions ...
james e mcgrew
This is done in plenty of shops using 4 x 4 machines, take a look at camaster.com and the forum of their owners
https://camheads.org
3/20/22       #6: Need CNC suggestions ...
What are your production numbers? Usually 4x4 machines are lighter duty and the components may not hold up to 8 hour days. Remember with a larger machine you can nest the work and do a full sheet of doors with a single loading. If the machine sits idle while loading, you aren't making money.
3/24/22       #7: Need CNC suggestions ...
Acctek  Member
If making cabinet doors, the size of 4*4 will be too small. It is recommended to consider the 1325 model. For woodworking, please refer to the website.
    • Limtech Industries, Inc.
