Small CNC recommendations
3/27/22
Harold morantz
Hi all, we are a 4 man shop with two sliders with tiger rip fences and great Bander and double line boring machine building euro style frameless cabinetry. Our use of gola profiles has increased and we need to have different height options of drawer faces and are now using jigs and a hand router to create the notch fir the profile. This is very time consuming. Our base side panels are 23.5x30 and I mama thinking if a small CNC machine set up with the programming to cut the j notch and the C notch quickly . I do not want to move to full CNC situation, thx
3/28/22       #2: Small CNC recommendations ...
james e mcgrew
Website: http://mcgrewwoodwork.com
Harold Camaster makes the Stinger, Built as industrial as the larger models and holds resale value.
they are sold used on the camheads.org forum as well, look at bottom of forum
3/28/22       #3: Small CNC recommendations ...
I just used a clamp on pattern and a good router. One pass and the knotch was done. Pretty sure a CNC could not do it quicker.
3/30/22       #4: Small CNC recommendations ...
JM
Rich is correct. By the time you were to load and locate the panel on a small router, you could have just used a pattern on a handheld router.
Just get someone with a router to make you some templates to use.
3/30/22       #5: Small CNC recommendations ...
Harold morantz
Website: http://mirantzcabinets.com
I have plenty of routers. But with a large project with 50 or 60 sides, I would think a CNC would be quicker. Looking into a small point to point that will also do line boring as well. Thx
4/1/22       #6: Small CNC recommendations ...
cabinetmaker Member
Harold
There are a ton of machines out there that could double your output, or in your case augment the sliders
It is a huge jump, but the move to cnc would bring a lot of consistency to the table
4/1/22       #7: Small CNC recommendations ...
You're wasting a lot of plywood by having the sides full height and notching like that.
4/1/22       #8: Small CNC recommendations ...
You're wasting a lot of plywood by having the sides full height and notching like that. Especially the ends that are hidden.
4/1/22       #9: Small CNC recommendations ...
Sorry about the double post. If you are doing 30 base cabinets on a job, why not buy a full size cnc and cut full sheets?
4/19/22       #10: Small CNC recommendations ...
Beta CNC Member
Website: https://forsuncnc.com/
You can find related machines on Google or B2B platforms such as Alibaba, eBay, the mini CNC router series is compact and affordable, ideal for small workshops or home use.
View larger image
5/1/22       #11: Small CNC recommendations ...
Rich Member
Did you ever resolve this?
5/1/22       #12: Small CNC recommendations ...
Harold morantz
I am not ready to convert to full CNC as we have two excellent sliders with tiger rip fences and my guys do not have CNC experience and at 71 years old, I am looking to cover the next 4-5 years and not ready for all the expenses of full flat bed CNC.,I am looking at the idea of a vertical that needs less floor space and is easier to learn and we can still cut very efficiently with the sliders. No vaccum pump needed and comes with its own program. A new generation homag will be 100k, but we are looking for a hood used one if possible.
Not just thinking of the gola profile alone anymore, but to do all the boring and grooving. New machines are 5 months delivery now but will keep our eyes out for a good used one.
    • Template Services
