Biesse 15 connect laptop pc to cnc
12/13/20
ozan Member
Hi,
Many years i have been using NC500 software on my xp loptop then transfer programs one by one via flopy disk to the CNC Biesse 15, Controller is NC410. I would like to connect rs232 cable between xp loptop and machine controller. how this works ? i dont have any dongle key. does it work if i just plug the cable com 1 ports between pc and controller ? all the pc data and the controller is the same. if i try this can machine get damage?
if this not possible my other idea is replace the floppy drive to wifi type drive not sure is that more slow to transfer and open the each program.
many thanks,,,
Ozy
12/14/20       #2: Biesse 15 connect laptop pc to cnc ...
Ozy,
I don’t know anything about Biesse, but I know my cnc is plug and play with a different computer, if you have the right ports for connection and the right operating software it should work fine.
As for floppy drives why don’t you use a USB drive, they make them with tons of storage, they are quick and compact.
Hopefully a Biesse owner can help you out.
4/19/22       #3: Biesse 15 connect laptop pc to cnc ...
erinnapizzut Member
I can only say about floppy drives, why don't you use a USB drive, they make them with tons of storage, and they are fast and compact. I recently got my laptop back after the data recovery, I never had questions like yours because I only use it for storing information and watching movies. However, even with simple users like me sometimes mishaps happen, but I was not worried, because I was convinced that salvagedata.com will fix it so quickly. I hope my little advice helps you in some way, good luck, buddy.
    • Limtech Industries, Inc.
