How to zero machine coordinates on the Richauto A18
9/7/22
Michael Member
Website: https://wattsan.com
The problem is that in the HOME point where the encoders are located, the machine coordinate system does not contain zeros, but rather some values. As a result, the working field is limited on one side and goes beyond the physical stops on the other. If you move the machine manually, you can move in.
How do I reset the machine coordinates to zero at the HOME point?
https://wattsan.com/product/wattsan-6090/
9/26/22       #2: How to zero machine coordinates on ...
Acctek  Member
After the Home capture is triggered, when the Home capture is restarted, the capture trigger flag of the corresponding axis will be automatically cleared.
    • Limtech Industries, Inc.
    • Better Vacuum Cups, Inc.
    • Template Services
