Life expectancy of flexible dust hose from your CNC to the header?
8/14/23
Matt
The past 6 or 7 years, I seem to have to replace the main flexible dust hose going from our dust collector header down to the gantry way more than we used to. Seems like I get barely 1-2 years out of it.
This has been on two different CNC routers (4x8 and 5x10), and we've rearranged the positioning of the overhead connection in a number of ways to help relieve the stress on it.
We're cutting a lot of melamine, which is quite abrasive, so it's understandable that it takes a lot of abuse. But this seems excessive to me.
The failure point is always at a stress spot-- either where it clamps to the gantry, or it clamps to the overhead connection. It seems like I can minimize one, but it puts all the pressure back on the other.
Given that we need the anti-static hose, this starts getting quite expensive quickly.
Any suggestions on what lasts?
8/14/23       #2: Life expectancy of flexible dust ho ...
Robert Duff  Member
Website: http://www.abettercloset.net
Do you have a ball joint at the top? Is the center of the hose supported?
8/15/23       #3: Life expectancy of flexible dust ho ...
james e mcgrew  Member
sounds like stress on the hose, mine id a good 5 years old om my Camaster and 2 on my sudaio
8/15/23       #4: Life expectancy of flexible dust ho ...
Matt
You guys are probably right.
We don't have a support or a ball joint on ours like Robert does. Ours is central over the middle of the 5x10 table. However, seeing how Robert has his makes me think of a few possibilities we could try here. Thank you for sharing that pic.
8/15/23       #5: Life expectancy of flexible dust ho ...
Derrek
Melamine is abrasive and just wears them out I get about 12-16 months
8/16/23       #6: Life expectancy of flexible dust ho ...
I've replaced mine once. Probably 1000 hours on it before it started sprinkling sawdust everywhere.
I don't have a ball, but a fairly long hose going straight up. The pipe is 14' off the ground.
10/13/23       #7: Life expectancy of flexible dust ho ...
routalot Member
I think with melamine you have to accept that the hose is a consumable item.It normally wears away the folds of the hose on the outside of bends.
    • Template Services
