Help installing 24vdc led light bar
2/19/24
Arrow  Member
I have contacted CR Onsrud about the install of their led light bar that can be added to their cnc routers.
Ive been told the electrical team would reach.....welll its almost been 1 month and I have not heard a peep from them....
Does anyone have any recommendations on where to jump the 24vdc? Its a IP65 light bar 24vdc led.
I'm sure it doesn't matter all that much. And I have jumped off the 24vdc lines for other addons on our older machines with no problems.
BUT being it is a brand new machine I just wanted to check in with the manufacture. And since they can not seem to respond or provide any assistance. I have came back to the woodweb for your help!
Thank you again!
2/19/24       #2: No response from CR Onsrud about in ...
Justin Morris  Member
Website: https://www.centexautomation.net/
Run a seperate 24V power supply like a 220V to 24Vdc style for 5Amps of load. Run a fuse from output of power supply in line with the +24Vdc going to light. If you want to run a switch, run a Normally open relay as well and tie the switch into that.
Onsrud taking over a month to answer back is why I do not suggest Onsrud to anyone.
2/21/24       #3: No response from CR Onsrud about in ...
Arrow  Member
Website: Arrowdesigncustoms.com
Justin Morris!! This man is everywhere!
PSA:
If you have a cnc router and need help/have questions/un-solved mysteries. THIS. IS. THE. GUY.
We had KOMO routers previously and he was the only person at KOMO that could help me get a new module installed properly. KOMO would just send me a "napkin" drawing of the wiring layout and it was not working. No one could figure it out at KOMO. I ended up getting Justin on one of my service calls, explained I could not get the wiring figured out. Long story short.... He took a look at the document KOMO was sending me. Said, this doesn't look correct. Then drew me a completely different diagram and BAM it worked. He gave me his personal number to get ahold of him afterhours while we serviced the machines at night. Outstanding tech, wealth of knowledge, and a genuine great person.
And yeahhhhh.... I realized I made a MASSIVE mistake buying a C.R. Onsrud shortly after receiving the machine. The amount of problems I have had with this machine in the past 6 months since purchase is nothing short of a nightmare. You would think a company that came from humble beginnings, owned by the original family, and only makes cnc routers would produce a better product..... or at least stand by it.... do be fooled by their advertisements...
The wiring for the light makes perfect sense. Thank you J!
2/21/24       #4: No response from CR Onsrud about in ...
Derrek
Don’t know how big your light bar is but HAFELE has 24v power sources for led lighting product that you can plug into any wall plug. I’ve added lighting in edgebander using this in past
    • Limtech Industries, Inc.
