Dust Collection
Subject: Re: dust/shavins into enclosed trailer
7/24/21
JT
hi, im new into this whole industrial dust collection systems and have a probably very basic question. the enclosed trailer im venting the dust into has 3 circular openings to it, one being the incoming dust/debri. How do i get rid of all the incoming air out of the trailer without any or minimal dust coming out of it? Do i just attach some sort of filter on the other trailer opening to let the air out and keep the debri and most dust inside?
Aside from small workshop dust extractors, i have no idea how to set up something industrial size. My woodlandia machine has a 12'' diam venting that will probaly have to be reduced to 10" to fit the trailer hole.
7/26/21       #3: dust/shavins into enclosed trailer ...
You are the reason there are professionals that can design and build a dust collection system that will work for you. You seem to be way out of your depth on this, so admit it and talk to a professional.
I have used Oneida and Honeyville Metal to design and build systems for me.
7/26/21       #4: dust/shavins into enclosed trailer ...
JT
Correct, hence the question, looking for general advice, tips ect. System isnt going and doesn't need to be very sophisticated. If i knew it already i wouldn't of had posted the question.
7/27/21       #5: dust/shavins into enclosed trailer ...
I can build anything out of wood, but am dumb as they come when it comes to duct collection.
Oneida will design a system for you. Give them your machine needs (CFPM per machine) and your fan size and duct work sizes and they will tell you how best to proceed.
I once worked in a shop where if the furnace kicked on, and you did not have a window open somewhere, the dust collection would suck the furnace fumes backwards into the shop and threaten to kill you. Get it right, and you will never have to think about it again.
7/27/21       #6: dust/shavins into enclosed trailer ...
Bill Member
If you are using a rotary airlock the returning air is set up in a closed loop. It gets blown into the side up high and they returned to the closed loop up high next to it.
We use a sealed 40 yard dumpster. It holds 6-8 tons on dust.
    • RT Machine Co.
    • Sandman Products
    • Air Handling Systems
    • American Fabric Filter Co.
    • Denray Machine
