Pickled oak cabinets
11/14/15
Chris
I have a job that I will have to build a pantry out of oak. It has to be pickled to match existing cabinets, I have a painter that is going to pickle it. I am not sure if they are red oak or white oak does one pickle better than the other. I would guess that white oak being lighter would look best.
11/14/15       #2: Pickled oak cabinets ...
JimHerron
The red oak will have a pink color when pickled white.
11/16/15       #3: Pickled oak cabinets ...
Paul Snyder  Member
Website: finishing.tips
Chris - matching the existing cabinets determines which wood is needed and the steps required to produce the finish. There's zero chance that applying a white stain on some oak and clear coating is going to match a factory pickled finish.
If your painter is an experienced finisher, he will be able to tell you what wood to use as well as the finishing steps needed for the match. If he can't do that, and give you a sample that the customer approves in writing, you should find someone else to do the finishing.
The first step is to get a large sample (like a cabinet door) approved before you do anything else.
11/16/15       #4: Pickled oak cabinets ...
jonmcay Member
Pickled stained furniture and cabinets are a major pain . A friend of mine had to strip and refinish a dining set 3 times because the customer wasn't satisfied. I run away from jobs like this even though the money always sounds good.
