Oak pores more pronounced
11/2/16
Richard
I have a project in 1/4 sawn white oak veneer where the client wants the pores of the oak to remain open or be more pronounced.
I thought not a problem, oak is perfect or this! Well after staining and 2 coats of CV I'm not getting the look they are after.
I have tried light and heavy coats of CV with no real difference. Any suggestions?
11/2/16       #2: Oak pores more pronounced ...
kevin
wire brush.
or lacquer.
or reduce the cv heavily.
11/2/16       #3: Oak pores more pronounced ...
kevin
this is what wirebrushing does. It can be less dramatic or more, depending on how you want it.
View larger image
11/2/16       #4: Oak pores more pronounced ...
Paul Snyder  Member
Website: finishing.tips
The solids content of CV is too high and it fills the pores more than you want. One finish that will provide an open pore effect is catalyzed vinyl - it is durable, but thin. I'm attaching a data sheet for one product that will do the job.
Super_Kemvar_C_Catalyzed_Vinyl.pdf
11/2/16       #5: Oak pores more pronounced ...
Paul Snyder  Member
Kevin - That's a nice look. Are you using a brush by hand, wire wheel on a drill, or panel machine? Do you dampen the wood first?
11/3/16       #7: Oak pores more pronounced ...
Richard
Kevin & Paul, between the wire brush and the catalyzed vinyl my samples turn out perfect, thank you so much.
Richard
11/4/16       #8: Oak pores more pronounced ...
kevin
Paul - we have a Supermax superbrush 49. It does full size panels. We dont wet the wood unless we need it to have a "torn out" weathered look. Running them dry gives you a nice even cut thats more controllable
9/29/25       #9: Oak pores more pronounced ...
Revel Woodard
Kevin – what specific brushes do you use with your super brush? I’m presuming a fine wire followed by some sort of nylon and wondering what gauge / grit nylon. Also how much are you pre-sanding? I would like to not have to touch the wood after the super brush if possible. I am doing a textured rift oak project, about 60 linear feet, and I am in the process of tooling up the brushing aspect of the job. The “” fine wire brush I received looks a lot more rough than I had imagined. I’m looking for something closer to the handheld Makita 4 inch wire brush drum sander in terms of wire gauge and density. Does such a thing exist? Can you re-wrap these brushes with your own custom configuration? If the limited options from Laguna don’t cover it? Thank you if you’re able to answer any of these questions.
