Methyl Hydrate finish repair
3/16/20
Mark B
A customer of mine has some damage to the finish of a dining room table that was made by a company in Canada. We rec'd this response from the manufacturer:
“Methyl hydrate (also known as methanol, methyl alcohol or wood alcohol). It can easily be found in hardware stores in the Paint section and is used to clean paint brushes.
The white ring and/or cloud you see on your table is caused by a hot item deposited on the table. The warmth of it pulls the lacquer up to the surface. The lacquer is one of the steps of our finishing process. The methyl hydrate allows the wood pores to open and let the lacquer enter the wood again. What you need to do is pour a generous amount of methyl hydrate on the stain and wait 1 or 2 minutes and witness the cloud vanish while you wait. Once it has gone simply wipe the excess liquid with a soft clean cloth. Your table will look fabulous again!
Make sure to use the liquid Methyl hydrate and not the gel since there is an ingredient in the gel that could damage your finish permanently.”
I have not heard of this procedure. Is it true?
Thanks,
Mark
3/17/20       #2: Methyl Hydrate finish repair ...
Shane Welch
Get yourself a can of aerosol mohawk Super blush retarder..... spray 12-16" from surface in light stroke until you see the white blush ring disappear.... do not touch the surface with anything! let it evaporate and dry.. if it comes back repeat procedure again until the ring works itself out.... let cure/dry and do not use for 24 hours
