Suggestion for a mini gun
7/15/21
mastercabman
Hello all
I'm looking at getting an additional touch up mini spray gun
Right now I have a CAT Tjr for touch ups/repairs,I like it
But I do need to get another but wondering if there are better mini spray guns out there
I was thinking of a LVLP?
I do need a mini gun that uses low CFM
Currently I can use my CAT Tjr with a Senco 1010 compressor
It works fine for the touch up I do
So,what do you suggest ?
Needs to be low CFM so that I don't have to set up a bigger compressor
7/16/21       #2: Suggestion for a mini gun ...
masterblaster
for on site i use an air storage tank, i'm guessing 10 gal that i use in line. this way i put the compressor further away, run a 25' hose to the tank then another hose to my gun. this way i really don't care about gun cfm's.
7/16/21       #3: Suggestion for a mini gun ...
JaySun
Anest Iwata makes a great little gun LPH-80.
Anest Iwata spray gun
7/16/21       #4: Suggestion for a mini gun ...
mastercabman
Master blaster
I'm trying not to have to set up a heavy compressor
I'm just looking for something small and low CFM so that I can use my little Senco compressor
I also don't want to set up a whole lot of equipment just to do touch ups
Jaysun
I will take a look at it
7/17/21       #5: Suggestion for a mini gun ...
masterblaster
I'm useing a small compressor, 3 gal tank size. i do make sure it is an oil type.
10/14/21       #6: Suggestion for a mini gun ...
Nick Sinderson
I have a Sata 4 touch-up gun. Great little spray gun. I think it only needs 4cfm so a 110 compressor works fine. I use it for on-site touch-up on clear and pigmented CV jobs. It does a very good job blending in the touch-up. Super durable but spendy.
