Japan Drier
12/8/21
Steven
A customer requests oil paint on kitchen cabinets; I used water based acrylic latex or water/urethane paint(no spray booth so not interested in strong solvent paints such as nitro lacquer paint, CV, etc. and no local suppliers want to mess with tinting white lacquers.)
I've used fast dry oil paint on one project in the past, and I couldn't touch the project for over a week without leaving fingerprints. If I were to try oil again would adding Japan drier give me a comparable dry and stack/pack time to the water based? How much could you add to a gallon without having issues? I spray with airless and fine finish spray tips.
On another note would lightly misting Japan drier on lightly wiped oil wiping stain help dry it out more quickly(yes, I realize ideally it should be wiped thoroughly:)
12/9/21       #2: Japan Drier ...
Daniel Shafner Member
The japan drier has the amounts to add on the label of the can. If you add too much, your finish becomes too brittle to behave.
No, you can't spray, spritz, brush, or rag on the japan drier onto a finish. Japan drier needs to be mixed into the finish. It's brownish-purple in color. Mixed in, the color generally disappears or is completely subsumed by the color of the finish.
12/10/21       #3: Japan Drier ...
Steven
Thanks for replying Daniel.
Do you have any idea how long to stack parts with foam and plastic wrap without blocking or foam or plastic leaving prints in the paint using oil paint with Japan drier added assuming 1 coat oil primer, 2 top coats, 80 degrees and 50% relative humidity?
Is it okay to add Japan drier to "fast dry" oil paint?
I spray fast dry oil primers all the time under water based so I wouldn't have a problem spraying oil top coats when requested if I could speed up the time to stack and pack to 2 or 3 days.
12/10/21       #4: Japan Drier ...
I can't advise you on stack time. We bake our finish at 140 degrees for 40 minutes (175,000 BTUs). After the pieces cool, we wrap and stack.
Unless you switch your finish type to a quicker drying alternative, your stuck, so to speak.
12/10/21       #5: Japan Drier ...
BH Davis  Member
I've always added about 1 teaspoon full of Japan drier per gallon of oil varnish. I've also always been told that too much has the opposite effect of retarding the drying time.
12/11/21       #6: Japan Drier ...
Mark B
Why not just tell your customer you dont spray solvents and sell them on something like KemAqua Plus or any other pigmented waterborne. You could likely make the substitute and not even tell them and they'd never know the difference and more than likely rave about the quality of the finish but then that leaves them telling everyone they come in contact with to demand outdated oil based paint on their cabs.
Bring in some pigmented water and spray a bunch of sample cards and show your customers the finish then simply tell them that _you_ specify the finish you are willing to work with (and stand behind) not them.
12/16/21       #7: Japan Drier ...
The performance of pro wb finishes exceed oil based paints.
If they want white cabs explain clearly that they will turn yellow over time.
