Raised Panel End Grain Too Dark
4/21/24
howard
Website: http://woodcontours.net
Did a group of maple raised panels, beveled profile. Shellac washcoat and oil based stain. Some of the end grain is too dark. Is there a practical fix for this. I was thinking of either taping off the area and lightly rubbing some mineral spirits to pick up some of the color? Or sanding it back? If there is no practical way then I will just go with it. I am experienced at spraying clear topcoats since the majority of my work is done this way, but I am not experienced at spraying tone coats. Appreciate your suggestions.
4/23/24       #2: Raised Panel End Grain Too Dark ...
Probably to late now. The time to use a rag and thinner is right away. But because I don't know the properties of your stain, and the fact that you have a wash coat under the stain it still might work.
The usual way to get a more uniform stain is with the sanding. Lets say you sand everything to 150 grit. You'd then sand those end grains at 220, including the ends of the stiles if they aren't mitered doors.
I use stain base with no colorants/pigments in it as a way to stop blotchiness and end grain darkness. Plus using the technique of wiping the stain off the end grain as soon as it's applied while letting the rest of the project soak for the amount of time you need.
All I can say is it probably can't hurt to try the spirits on a rag and try to rub some of the stain off. But be careful about the surrounding areas because they can go lighter too.
4/24/24       #3: Raised Panel End Grain Too Dark ...
As Leo mentioned you typically sand the end grain finer. This can work pretty well with hardwoods. If it's a softwood like pine or poplar you can use a pre stain conditioner. One coat of Sealcoat shellac works as well before the stain. It limits the amount the wood will absorb.
