Forestry
SYP inventory
3/10/24
Learner Member
To start with there will be many follow up questions.
Just wanted to get that out there.
Question- is there a standard formula used to determine tonnage of logs in a stack? If so is it different for longleaf and loblolly?
3/15/24       #2: SYP inventory ...
The MW Studio  Member
Website: themillworkstudio.com
One commonly used approach is to calculate the volume of the logs in the stack and then convert that volume to tonnage using the average weight per unit volume for the specific species of tree. This can involve measuring the length, diameter, and sometimes the density of the logs.
As for longleaf versus loblolly, while the basic principles might remain the same, there could be differences in density and moisture content between the two species, which might affect the weight-to-volume conversion. So, it's possible that adjustments might need to be made depending on the species you're dealing with.
    • INNERGY
    • Denray Machine
    • Limtech Industries, Inc.
    • Forestry.com
    • Sandman Products
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Better Vacuum Cups, Inc.
    • WalzCraft
