Furniture Making
Subject: Re: Core telegraphing through face veneer?
6/9/21
Jeff Member
I'm building a large pivoting entry door in the order of 63" x 96". An internal steel frame will be clad with ½" Medex (or a similar exterior-grade MDF) with 1-2" solid maple on the edges. I'll then veneer the slab with 1/16" maple.
I'm concerned about the joint between the Medex and maple telegraphing through the face veneers. I've had core joints telegraph through 1/42" veneer before, but will be using 1/16" for this job.
I thought about laminating a phenolic backer to the cores before veneering, but they're not available wide enough in my area.
I've also considered cross banding veneer over the cores.
What are your thoughts? With 1/16" veneer, will the telegraphing show?
If it matters, as this door is exterior, I will be using epoxy for everything (core joinery, veneering, etc.). I'll also cut the solid maple edge banding from quarter-sawn material to ensure it expands across the width of the door (there will only be an inch or two of edge banding, so I'm not concerned about the door swelling in width).
6/9/21       #2: Core telegraphing through face vene ...
I have made large walnut slab exterior doors with 1/16" veneer. I didn't experience any print through of the solid edge to particle core joint. I was gluing with type 2 pva and left the joints for 24 hours to stabilize before planing flush. You are using epoxy so you won't have added moisture to contend with.
Cross banding is the preferred approach if you want to be absolutely sure.
I would be concerned about any hollows under the mdf that may cause pressing problems. If you are vacuum veneering then how will you ensure the faces will remains flat? I would be worried about face flatness in a platten press as well.
6/10/21       #3: Core telegraphing through face vene ...
Jeff Member
RE: face flatness: I had already planned to fill the spaces between the steel frame members with pink or blue styrofoam insulation. I don't want any chance of condensation forming inside the door (I also plan to fill the hollow steel frame members with pour foam for the same reason).
At any rate, I hope the styrofoam serves the dual purpose of keeping the panels from caving in during the veneering process. In addition, I'll probably dial down the pressure on the vacuum.
6/14/21       #4: Core telegraphing through face vene ...
Dave Sochar Member
Crossband is the preferred way of insuring that telegraphing of the core will not be detected.
    • CP Adhesives
    • Anver Corporation
