Furniture Making
sandpaper backing vs. polishing
12/12/20
brad hays Member
When sanding resin in an epoxy resin table up to 3000+ grit with a DA/RO sander, would adhesive-backed sandpaper give a more flat/accurate polish vs. hook and loop paper due to the potential for unevenness in the velcro system?
12/12/20       #2: sandpaper backing vs. polishing ...
rich c
A lot of polishing is done with a foam or lambs wool bonnet. They are way softer than velcro backing.
12/14/20       #3: sandpaper backing vs. polishing ...
Jim Clark Member
You'll never see a difference between velcrow and PSA, especially at 3000 grit.
If you want a flatter (straighter) finish
you'll have to work your way up through
the grits starting at 1000 or lower.
It's just like auto clearcoat.
To get it dead straight I start with 400 or
600 grit for cars. That's way overkill for
woodwork. But the fine grits will not
straighten, they'll only polish.
12/17/20       #4: sandpaper backing vs. polishing ...
Snaglpuss
Make sure your DA/RA has a new flat pad.
6/29/21       #5: sandpaper backing vs. polishing ...
Adam West  Member
The newer hook and loop pads are not your grandpa's J hook. The hooks resemble a T and the stiffness and flatness is top notch. If you still have the J hooks look for the newer hooks.
    • CP Adhesives
    • Anver Corporation
