Furniture Making
Table extensions
3/14/22
Corey Member
Building a cherry table soon for a customer. 4’ wide by 6’ long with need for 3 16” leaves. Looking for advice on table extensions. Metal better than wood? Equalizer stretchers better than regular? Customer had mentioned something about European sliders but could not find it again. I have repaired and worked on a lot of old ones with refinishing furniture for 30 years. Seems quality wood is the main factor and camber in the length of the table I am building. Customer is supplying kiln dryed wood from there property. Will definitely check moisture when I get it to shop. Thanks for any advice and help.
3/14/22       #2: Table extensions ...
duster
I've used lots of both types of slides, and I've come to prefer the steel ones over wood, especially for longer extensions. The ash table shown was 12' long with the 2 - 24" leaves in place. The steel slides were 72" long in the closed position, and opened up 50" No sag, dead level.
Equalized slides are for fixed base pedestal tables, like the alder one shown.
Wood slides work fine for smaller tables and are less expensive. For a large table and long term functionality, I go with steel.
My source for Watertown steel slides is Moin Hardware @ tableslides.com
View higher quality, full size image (800 X 455)
View higher quality, full size image (800 X 393)
3/16/22       #3: Table extensions ...
Dave Sochar Member
"Walter of Wabash" makes a good product, both regular slides and extension slides. All wood, but easy to work with.
We recently used them to make a 32' long table. Actually, it was two tables, 6' round, with a bunch of extensions so they could be joined and make 32' long by 6' wide.
8/1/23       #4: Table extensions ...
HubertDalton Member
I appreciate the advice. I will keep it in my mind.
    • CP Adhesives
    • Anver Corporation
