Furniture Making
Recipe for failure
3/31/23
Mike Barker  Member
I have been asked to build this table. The shelf at the bottom noting the grain direction and that of the stretcher looks like a recipe for failure. The widest part of the bottom is 12". Any suggestions to make this work. I suggested to use a trestled beam in place of the shelf. She isn't convinced.
View higher quality, full size image (3024 X 1451)
3/31/23       #2: Recipe for failure ...
I think there are ways around the problem. Fasten the center only hidden underneath and let the ends float so they can move with humidity.
If you feel that is not enough structure you could attach the shelf like a table top so it can move as much as it needs to.
Good luck.
4/1/23       #3: Recipe for failure ...
It appears the designer wants to make the joint to be a visual feature with the lengthwise stretcher let into the cross braces. There will be a stress riser at the base of the tenons. I would suggest fully enclosed tenons with the outer mortises lengthened to allow some movement. Glue the central joints, peg the outer ones. To add visual interest you can do through tenons but you will have to be sneaky with the outer ones to avoid showing the oversized mortises. I would make end grain caps to imitate the through tenons.
4/1/23       #4: Recipe for failure ...
If you use quarter sawn, wood movement won't be a problem at the joint.
4/5/23       #5: Recipe for failure ...
Mike Barker  Member
Thank you all so much for your help. I think I can sell her on the through tenons. I feel more comfortable allowing for wood movement. I will have to get a little crafty with small tenons on the end grain caps.
5/2/23       #6: Recipe for failure ...
Chippy1987 Member
Love to see the end product there @MarkBaker!
6/8/23       #7: Recipe for failure ...
Mike Barker  Member
Website: http://wooddimensionsky.com
The table is finally complete. The lumber was sourced from a downed tree on the client's property. Quarter sawn and dried to 6-8%MC. I decided I would try something a little different, using relief cuts to address my concerns about movement in the bottom stretcher. Honestly I'm kinda keeping my fingers crossed.
View higher quality, full size image (2412 X 1908)
View higher quality, full size image (2868 X 1908)
6/13/23       #8: Recipe for failure ...
Dave Sochar Member
Nice work. Your decision to make relief cuts in the stretcher is a good one. It is not hard to find precedent on the detail. Three small cross sections will have negligible movement compared to one larger joint.
8/29/23       #9: Recipe for failure ...
David William  Member
Building the table with the shelf as designed might indeed pose a challenge due to potential wood movement issues. To ensure stability, consider using breadboard ends on the shelf and stretcher. This allows for wood expansion while maintaining structural integrity. If your client prefers the original design, using a stable wood species and accounting for seasonal wood movement with proper joinery could help. However, a trestled beam could provide a more reliable solution, offering support without compromising aesthetics. It's important to discuss these options and their implications with your client to find a suitable compromise.
11/15/23       #10: Recipe for failure ...
Mohammad Sheikh Foyjul Islam  Member
Website: https://elegantinterior.com.au
The design in the image and the final work look so different... You make the work so beautiful and awesome.. Nice work..
    • CP Adhesives
    • Anver Corporation
