Furniture Making
Dark Burl Banquette and Table
2/15/24
vince Member
A client asked for a quote to build something similar to the attached photo in a dark "espresso" stained burl wood.Legs. Photo also attached of the finish/figure she is after.
Am I best off planning this as veneer over mdf? I have done a little veneer work, but never built curved furniture legs.
Is solid lumber an option?
What species would be best in your opinion?
View higher quality, full size image (500 X 717)
2/15/24       #3: Dark Burl Banquette and Table ...
vince Member
2/16/24       #4: Dark Burl Banquette and Table ...
I don't see any curved legs.
2/16/24       #5: Dark Burl Banquette and Table ...
vince Member
Apologies. Curved bench end.
2/17/24       #6: Dark Burl Banquette and Table ...
Pete
I would tell the client to veneer the table top in burl and do the banquet seat in solid walnut. Veneer the top on whatever core you want with a solid wood edge. If they want everything in burl, its doable but time consuming so charge accordingly. If they want everything in burl, veneer it on a stable solid wood.
2/17/24       #7: Dark Burl Banquette and Table ...
vince Member
Thank you Pete!
Exactly the support I needed.
2/20/24       #8: Dark Burl Banquette and Table ...
chris
if you are going to veneer top i would use mdf and make sure you balance the panel crossplying each side so you use 4 sheets of veneer. 2 on each side.
And solid wood for bench.
2/20/24       #9: Dark Burl Banquette and Table ...
vince Member
Chris:
Do you mean a lesser grade of veneer running crossways under the walnut burl veneer?
If so, what type of veneer for the one under the burl?
Also, I assume I can use cheaper veneers like oak to balance on the bottom of the table top?
2/21/24       #10: Dark Burl Banquette and Table ...
chris
yes. we currently use sapele. it is a nice closed grain wood and not too expensive.
I would use that on both sides or something similar.
3/28/24       #11: Dark Burl Banquette and Table ...
Erick Member
Yeah sapele is great for its excellent stability, durability and super cozy reddish-brown color
    • CP Adhesives
    • Anver Corporation
