Floating a ceiling
8/16/14
Steve Sponsor - Parts Cutter CNC
Website: http://www.johnsamuelinc.com
Hello All,
Is there an actual thickness limit on how much compound you can float a ceiling out?
Thank you
Steve
8/17/14       #2: Floating a ceiling ...
james mcgrew Member
Before anyone says "Hey call the Drywall Guy" I am going to think you are installing woodwork and have a bad ceiling in front of you ??
8/17/14       #3: Floating a ceiling ...
Yes James
Its wavy. We will do our best to cheat the crown but there will be gaps.
Steve
8/17/14       #4: Floating a ceiling ...
james mcgrew Member
Comes down to accepting the Substrate, yes you can float depth in layers, would not do it all and thick at once, I have seen them Nail in .25 inch sheetrock to eat space then do the float. I have also seen a sheetrocker make a small 1.5" "soffit to level then run the crown
photo document and notify the owner, me I like to get paid !!
8/17/14       #5: Floating a ceiling ...
Thanks James
Is there a limit to how much you can float out in terms of layers? 1/4"..1/2"?
8/17/14       #6: Floating a ceiling ...
Just my .02 but if your going to try to float it using redimixed youll have a nigtmare of a time floating t thick and it wil create more work in the end. If you are going to have to float out very deep areas its best to use setting compound as it doesnt drag, shrink, crack, and moreso it sets fast and recoats can be in minutes.
A good plasterer could float a large room in a single day alone but they are less common in many areas.
9/18/14       #7: Floating a ceiling ...
Samsood Member
Hi Steve,
There is no limit of thickness of the compound used for ceiling but there is a minimum amount and it varies according to the type of soil and the temperature. You need to have a proper checkout before the usage.
