Glueing 4/4 solid to a 1 1/2 Aluminium core
7/20/20
Ben Cochran
Looking for a second opinion on the stability of this concept and the best glue to use. It will be a dining table measuring 3” thick x 34 w x 129 long. I would use the honeycomb Aluminium core with 4/4 solid rift oak top and bottom
7/21/20       #3: Glueing 4/4 solid to a 1 1/2 Alumin ...
Dustin Orth
You need to understand wood movement, this will get you a potato chip in the end. Never glue wood to another material that doesn't move the same. Im sure others will chime in here as well. Just a real bad idea.
7/21/20       #4: Glueing 4/4 solid to a 1 1/2 Alumin ...
bill
What is the purpose of the aluminum core?
7/21/20       #5: Glueing 4/4 solid to a 1 1/2 Alumin ...
I think you need to spend some time learning the basics of the craft. You might also question the veracity of the client that would hire someone with demonstrably short knowledge for such a project.
When you did the calculations for radial exchange, what were the parameters of RH you used? Starting RH?
Short answer to your question - No, or maybe Yes and No.
    • Texas Woodworking Festival
    • J&P Machines
    • Forestry.com
    • Better Vacuum Cups, Inc.
    • Laguna Tools
