Pre-mil
3/16/21
I've never seen a separate aftermarket pre-mil unit available for an edgebander. Most cases it would probably be difficult to fit on an edgebander that didnt have one included to begin with.
What is the best technique to trim laminate before edgebanding?
3/16/21       #2: Pre-mil ...
Jared Member
A premill station on an edgebander is one or two shaper heads that trim a whisker off the panel. If you need to do it separately from the bander, one way would just be a shaper setup with an offset fence.
3/17/21       #3: Pre-mil ...
Alan F.
Your bander may have an empty space where you can add a premill station
A-
3/18/21       #4: Pre-mil ...
The edgebander I have dosent look like there is room for a premill unit.
This seems to have always been an important point in building laminate doors/panels. Getting the edge prepared correctly to edgeband. Ive always been stuck with a hand router to cut as close as possible to the panel. I may start a table saw sequence to cut the edge after laminating. I think referred to as a bottleneck.
8/5/21       #5: Pre-mil ...
Any best cutter head arrangement for pre mill on a shaper? Straight, helical or spiral?
8/6/21       #6: Pre-mil ...
Allen Chalifoux
We tried using a shaper with a straight cuter years ago and had problems with tear out on the trailing edge.
A true premill cuter may work better due to the angled inserts similar to a mortise compression bit. Allen
