Sawing and Drying
Should Wood Crosscuts from Stumps Be Sealed
1/26/22
howard Member
Website: http://woodcontours.net
Just started getting into this, making table tops from what I hear are called wood cookies. I seem to be getting conflicting views on whether or not to seal both end grain sides. I have Anchorseal. So, should they be sealed or will this just slow down the drying too much. Appreciate any help in clearing this up.
1/31/22       #3: Should Wood Crosscuts from Stumps B ...
Post where you like, you will still hear this is a bad idea.
Wood shrinks as it dries. You will spend a small fortune on Pentacryl if you proceed that direction, and then how do you finish when the penta is borne by a wax?
The best test is: Where have you seen wood discs the same diameter you have being used as table tops? What do you think the reason is? Does your Woodweb search indicate that this comes up about 1-2 times a year, and the answers are always the same. Cracks. Big ones.
2/4/22       #4: Should Wood Crosscuts from Stumps B ...
GeneWengert-WoodDoc
There is a chemical, polyethylene glycol 300, that can be soaked into green wood. It replaces the water with PEG-300. pEG-300 bulks the wood so it cannot shrink when it is dried. Works great if the wood is porous enuf to let the chemical absorb throughout the piece.
Once dry, the wood can be finished with polyurethane, and maybe other finishes.
Ethylene glycol is antifreeze and it is poisonous to humans and others. However, if you add 300 of the ethylene glycol molecules together into a new molecule, then the properties change. It is not a liquid, but a gel. It is not poisonous. Many medicines use a molecule of 3000 ethylene glycol molecules in a chain, so it is healthful. Back to PEG-300 (sometimes PEG-1000 is used with wood.), it is the bulking property that makes it work. The chemical prevents shrinkage. So, car antifreeze or straight ethylene glycol will not work I. Preventing shrinkage.
    • Forestry.com
