Solid Wood Machining
sanding belt pitch and resin remover disposal
3/15/16
john Member
Hello-
Is anyone familiar with Nu-Life Pitch and Resin remover? It works great on cleaning up sanding belts, and as I'm sure you all know, sanding belts are a major price point.
My question relates to the disposal of this product. I understand the point of getting a 55 gallon drum and dunking the belts in, but how would you dispose of the solution and rinse water, once it gets too mucky to use? The msds suggests following federal laws, but not sure what that exactly means. Disposal company? The cost savings on reusing belts may be drastically cut if I have to have it disposed of professionally. Any thoughts would be helpful. Thanks!
3/15/16       #2: sanding belt pitch and resin remove ...
Disposal might be $0.35 a gallon or around $20. Not as expensive as you might think. Call Waste Management.
3/24/16       #3: sanding belt pitch and resin remove ...
Adam West  Member
Just to be clear, you are talking about removing resin from a pine or something sappy?
If you are simply cleaning your belts to get more life after they are dull and used up you will be dumping buckets of money down the drain in hand sanding and rework.
There are solutions that don't require dunking the entire belt in it. I see pressure washing as the most common method once the solution has softened the resin.
