Solid Wood Machining
RE: Grit of wood using a Planer
8/5/19
Tommy
We have a 2-foot planer that is cutting very smooth, is there a way to tell what the grit is of the material coming out of the planer? Such as 200, 150, 100 etc.
Is there a way to test the wood?
Also, who makes the best 2-foot blades for longevity for a planer?
8/6/19       #2: RE: Grit of wood using a Planer ...
Mark  Member
Website: ragnarhandcraftedfurniture.com
Hey Tommy, when wood come out of a planer it will have ridges left from the knifes. They are small, perhaps 10-20 per inch depending on feed rate and cutter head. This is your first objective to remove. Whatever grit you use to remove it is now the size of your scratch and you can proceed from there. But boards don't come out of a planer with a scratch pattern.
8/6/19       #3: RE: Grit of wood using a Planer ...
When you posed this question a month ago, you got responses trying to explain that your question was not meaningful, and any answer would be the same.
Knife cutting and sanding are two separate operations. They do not compare directly, so no one will or can give you an answer to your question. To continue asking this same question may eventually get you the answer you want to hear, but that will not help you at all.
Find the knife marks - KCPI- your equipment makes, then post a question about where you should start sanding, and where you want to finish up.
8/8/19       #4: RE: Grit of wood using a Planer ...
In case you didn't read the answers last time.
http://www.woodweb.com/cgi-bin/forums/swmf.pl?read=834532
8/8/19       #5: RE: Grit of wood using a Planer ...
duster
I bet Norm Grimberg has the answer...
8/17/19       #6: RE: Grit of wood using a Planer ...
As to who makes the best knives, that depends on what kind of head it has.
Tersa? Terminus? Just a straight hss knife? Helical hss knife?
What kind of material are you running? Standard domestic hardwoods? Anything freaky? Do you plane through a lot of glue?
A lot of things affect knife choices
