Solid Wood Machining
shaper tooling for large stopped mortise
9/23/21
Willis B
I need to make what are essentially long mortises in the back of some thick OG doug fir shelves (2 1/4") and mantels (5 1/4") to accept hardware. I'm thinking an efficient way to do this is with the shaper. The mortises can't show on the ends, so I need to start/stop in the middle of the beam with the help of a subfence with stops. Two mortise types: 1 3/8" tall x 3/8" deep for the shelves, and 2" tall x 1" deep for the mantels. Length varies from 28 - 54 inches.
My concerns are: 1- safely dropping the wood onto the cutter, and stopping at the end. 2 quality of cut or blowing out the end grain as I approach the end (current design leaves me 3/4" with a 6" dia. cutter)
Would a dado stack with many teeth accomplish this better then an carbide insert groover? Is there a tooth hook angle that would be advantageous? I'm assuming larger diameter is better. I'm hoping to invest in a single tool for both mortise sizes so adjust ability is necessary.
Up till now I've been doing this with a spiral router bit and an edge guide, works ok but takes a long time and makes quite a mess. CNC would make short work of this but that's not in the cards.
10/1/21       #3: shaper tooling for large stopped mo ...
Why not a dado head on the table saw and then square out the end with a chisel and mallet?
10/4/21       #4: shaper tooling for large stopped mo ...
Kevin Jenness Member
The safest way is to pivot the work into the cutter with the leading edge against the shaper fence and the trailing edge sliding against a wide stop as you enter the cut. I have done it the other way with a 3/4" tall cutter, pivoting from the back, without a problem, but I can imagine a large cutter self-feeding and causing the utmost damned astonishment.
Take a look at post #13 by Joe Calhoon in the linked thread to see what I mean.
I would not expect a problem with blowing out the end cut with 3/4" to spare, but you could run the groove on an oversize blank before cutting to length.
I would use the smallest diameter cutter that will get the required depth in order to reduce the length of the radiused inside corner. I don't think you will gain anything by using a dado head versus a square cutter.
Rotating the workpiece flat on the shaper table seems safer to me than dropping it on edge on a tablesaw. In either case a backstop is esssential for safety. I would make these cuts in two or more passes rather than one heavy cut.
dropping in
