Wood NetWork
Subject: Re: Delta saw lock knobs
10/13/20
Donn  Member
I was lucky enough to acquire a late 1940s or early 1950s Delta table saw for free. At that price it made sense to upgrade the motor, replace bearings, upgrade the fence, and add a magnetic switch. The only thing lacking is the ability to lock the blade lift and blade angle. Without that I get some drift and need to repeatedly adjust the blade angle when cutting multiple parts with the same angle.
When I got the saw there was one knob in the lift wheel. I ordered two replacements which are quite different. With the old knob it appears that there was another part(s) that went inside the shaft to bear on what looks like a v-shaped wedge to force it out and lock the shaft. With the replacement part I can screw it in until it bottoms but it does not lock the shaft.
The parts diagram I have been able to find may not be the correct one for the saw. This seems to be the closest of the diagrams I have found. You can see that there is nothing in the diagram about the inner part that the lock knob bears on. I have not found an ID plate on the saw. If anyone has a better idea of the vintage of the saw or knows anything about how the lock knobs are supposed to work, I’m all ears.
View higher quality, full size image (1024 X 792)
10/16/20       #2: Delta saw lock knobs ...
Matt Calnen
Go to vintagemachinery.com They will have all the information on how to know how old your saw is and the appropriate manual. I believe on your saw there is a brass “bullet” that gets pushed in as you tighten the handle. If it’s not in there the locks don’t work. You can buy them on eBay and other sources. But getting the correct manual is the first thing I would do. I am lucky enough to have a ‘39 unisaw.
10/16/20       #3: Delta saw lock knobs ...
Donn  Member
I could not find a "vintagemachinery.com." Did you mean "vintagemachinery.org?"
10/16/20       #4: Delta saw lock knobs ...
Matt Calnen
Yes
10/16/20       #5: Delta saw lock knobs ...
BH Davis  Member
Very nice job restoring that saw.
Is that a 1970's Craftsman all metal skillsaw stashed below the saw table? I still have a few of those. They were made by Singer.....as in sewing machines I believe.
10/17/20       #6: Delta saw lock knobs ...
Donn  Member
Yes. I've had that Craftsman saw for 40+ years. Doens't get used much which is why it's tucked under the bench. Thanks for the comment about the table saw.
    Excel Wood Products
